What is MPG
MPEG formats are commonly used as multimedia medium. MPEG media formats typically use MPEG-1, MPEG-2, and MPEG-4 AVC are older formats famously used for media coding while MPEG-2 systems transport streams and program streams.
What is AVI
AVI stands for Audio Video Interleave. It contains both audio and video data in a file container keeping the audio in sync with video playback. AVI also support multiple streaming audio and video, however this is rarely used.
Convert MPG to AVI
Simple, easy and fast. Just drag and drop your MPG file into the converter and it'll be converted in a few seconds.
Fast MPG to AVI conversion
Our media converter can help you convert your MPG file into AVI with just 1 click.
Convert MPG to AVI for free
Converting MPG to AVI is free and easy to use. We also offer fast downloads for the newly converted files.
How to Convert MPG to AVI Online
Follow these quick steps to convert a MPG to AVI online:
Step 1
Upload your MPG
Upload your MPG file through the upload media pane above. You can drag and drop any MPG file into the drop zone, or choose a file from your online drives such as Google Drive, Dropbox and more.
Step 2
Download AVI File
Once the conversion is done you can download new AVI file onto your computer. From here you may choose to convert another file or try our other File Conversion Tools.
Did you know?
You can convert to other formats
Not only can we convert MPG to AVI. We have various media converters at your service for free as well.
Easy conversion tools
The quality of audio and video will affect the file size of the media. Since MPEG has been around for over 30 years, its compression is inadequate compared to other modern media codecs. In other words, the quality of MPG may be worse even if its file size is the same as other media codecs when storing.
Our conversion tool will help you convert MPG to AVI without download or installing any software. You can convert online in any browser.
Our conversion tools are great if you want a quick and easy way to convert your MPG files to AVI in your web browser.
Converting MPG to AVI is fast and efficient. Instant result is expected for most files.
AVI includes very high quality audio-fidelity, so we can store AVI media in DVD to present the initial audio and video works. Moreover, since it was developed by Windows, it runs on all Microsoft® and most non-Microsoft® operating systems, which makes it a common video format in our daily lives.
AVI is known for its high quality. However, it also has a much larger file size than other media formats. In this case, we can choose to save our work in AVI or in another format, depending on our storage purpose, and the suitability of our device. If we want to store our work in the best quality, then AVI would be a good choice for you.
Although AVI is widely used in Microsoft, it is not easy for us to play AVi in Mac and iPhone as it default player, Quicktime, does not support playing it. If we want to play IOS system, we may need to install third plugin, download other player or convert it to other formats before playing.
Since AVI files may not contain attachments such as subtitles and fonts, we need to save them as a separate file when storing. We can also choose to hardcode it into the video stream.
