Reduce file size while maintaining optimized PDF quality.
Optimize any PDF document to get the smallest file size while using Compress PDF Tool. By reducing the size of a PDF you it will shrink and occupy less storage space. It also makes it easier to attach or copy wherever you need.
Fix typos, change font settings, and add new content. Edit graphic content: resize, apply filters/effects, and more.
Upload and start editing a large PDF in seconds. Our PDF software is optimized for handling large PDF files, the kind of files that other PDF tools just can't handle.
Our flipbook reader makes it easy to share and read PDF files online via URL, social media or as embedded content.
OCR technique will analyze texts and turns letters into editable text. AI Character recognition is highly accurate while maintaining a fast conversion process.
Our online PDF software operates in the cloud. You can access your PDF file through any web devices and browsers: Chrome, Edge, Firefox, Safari, and more.
All our PDF tools do not store your files on our server longer than needed. After a short period of time your files and results will be automatically deleted.
Follow these quick steps to compress PDF files online:
Upload your PDF file through the upload PDF pane above. You can drag and drop any PDF file into the drop zone, or choose a file from your online drives such as Google Drive, Dropbox and more.
Simply select a compression format that suit your needs. Then press Compress, and your file will be automatically compressed to a smaller size.
Once the compression process is finished, you can then Download the newly created PDF file.
