Select and rotate specific pages then create a new PDF document.
Review and rotate your PDF pages visually then save it as a new PDF document. You can also rotate each pages into different direction or even a 360 degree rotation.
Fix typos, change font settings, and add new content. Edit graphic content: resize, apply filters/effects, and more.
Upload and start editing a large PDF in seconds. Our PDF software is optimized for handling large PDF files, the kind of files that other PDF tools just can't handle.
Our flipbook reader makes it easy to share and read PDF files online via URL, social media or as embedded content.
OCR technique will analyze texts and turns letters into editable text. AI Character recognition is highly accurate while maintaining a fast conversion process.
Our online PDF software operates in the cloud. You can access your PDF file through any web devices and browsers: Chrome, Edge, Firefox, Safari, and more.
All our PDF tools do not store your files on our server longer than needed. After a short period of time your files and results will be automatically deleted.
Follow these quick steps to Rotate PDF Pages online:
Upload your PDF file through the upload PDF pane above. You can drag and drop any PDF file into the drop zone, or choose a file from your online drives such as Google Drive, Dropbox and more.
Review and select which page(s) you would like to rotate from the PDF file. Select the direction of which the rotation should rotate. Rotate as many pages as you want even if they are rotated towards different directions.
Once the PDF rotated pages are done processing, you can then Download the newly created PDF file.
